Introduzione
Replacing the motherboard in a phone becomes necessary if it encounters severe damage from water exposure, electrical faults, or physical trauma, leading to critical malfunctions. A malfunctioning motherboard can disrupt various functionalities, such as the device's ability to power on, connect to networks, or process information.
Swapping the motherboard restores the phone's core functionality, ensuring stable performance and resolving issues stemming from internal hardware failures.
Cosa ti serve
Locate the small indent on the back right bottom corner of the phone.
Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
Locate the battery in the middle of the back of the phone.
Push in and up on the battery to remove it from its slot.
Put the battery aside.
Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
