Introduzione
If there is damage to the camera of your ZTE Maven 3 z835, follow this guide with the given steps in an earnest manner. You may need to replace the camera if its images appear blurry and disoriented, or if there are apparent cracks on the camera itself. This guide mainly applies to the back camera which is 5 Mega Pixels.
The front camera on the phone can be found in the frontal left area of the device.
For this guide, you will need to utilize a pry tool, a Phillips #00 screwdriver, and tweezers. You will need to follow these steps closely since any damage done to the hardware within the device can make it more difficult to fix.
Cosa ti serve
Locate the small indent on the back right bottom corner of the phone.
Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
Locate the battery in the middle of the back of the phone.
Push in and up on the battery to remove it from its slot.
Put the battery aside.
Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
Detach the ribbon cable connecting the camera in the top middle of the phone.
Using this same method, grab the tweezers and insert the replacement camera.
