Salta al contenuto principale
ZTE Lever Rear Camera Replacement
Cosa ti serve
  1. ZTE Lever Rear Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
    Chiedi a FixBot
  2. ZTE Lever Rear Camera Replacement: passo 2, immagine 1 di 2 ZTE Lever Rear Camera Replacement: passo 2, immagine 2 di 2
    • Use an iFixit opening tool to separate the back from the device.
    Chiedi a FixBot
  3. ZTE Lever Rear Camera Replacement: passo 3, immagine 1 di 2 ZTE Lever Rear Camera Replacement: passo 3, immagine 2 di 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
    Chiedi a FixBot
  4. ZTE Lever Rear Camera Replacement: passo 4, immagine 1 di 2 ZTE Lever Rear Camera Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
    Chiedi a FixBot
  5. ZTE Lever Rear Camera Replacement: passo 5, immagine 1 di 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
    Chiedi a FixBot
  6. ZTE Lever Rear Camera Replacement, Rear Camera: passo 6, immagine 1 di 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
    Chiedi a FixBot
  7. ZTE Lever Rear Camera Replacement: passo 7, immagine 1 di 3 ZTE Lever Rear Camera Replacement: passo 7, immagine 2 di 3 ZTE Lever Rear Camera Replacement: passo 7, immagine 3 di 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
    Chiedi a FixBot
  8. ZTE Lever Rear Camera Replacement: passo 8, immagine 1 di 2 ZTE Lever Rear Camera Replacement: passo 8, immagine 2 di 2
    • Using a plastic opening tool, disconnect the camera from the motherboard.
    Chiedi a FixBot
  9. ZTE Lever Rear Camera Replacement: passo 9, immagine 1 di 1
    • Remove the camera from the phone.
    Chiedi a FixBot
Conclusione
USF Tampa, Team S5-G2, Passmore Spring 2018 Membro di USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 53
Tutti i Tempi: 312
