Salta al contenuto principale
ZTE Lever Front Camera Replacement
Cosa ti serve
  1. ZTE Lever Front Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Front Camera Replacement: passo 2, immagine 1 di 2 ZTE Lever Front Camera Replacement: passo 2, immagine 2 di 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Front Camera Replacement: passo 3, immagine 1 di 2 ZTE Lever Front Camera Replacement: passo 3, immagine 2 di 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Front Camera Replacement: passo 4, immagine 1 di 2 ZTE Lever Front Camera Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Front Camera Replacement: passo 5, immagine 1 di 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Front Camera Replacement, Front Camera: passo 6, immagine 1 di 2 ZTE Lever Front Camera Replacement, Front Camera: passo 6, immagine 2 di 2
    • Unscrew the three 1.6mm Philllips #0 screws on the plastic cover that are near the top edge of the phone by the camera.
    • Pry off the plastic cover using the iFixit opening tool.
  7. ZTE Lever Front Camera Replacement: passo 7, immagine 1 di 2 ZTE Lever Front Camera Replacement: passo 7, immagine 2 di 2
    • Unplug the front-facing camera press fit connector cable using the iFixit opening tool.
    • Remove the camera from the motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 110
