Salta al contenuto principale
ZTE Jasper LTE Speaker Replacement
Cosa ti serve
  1. ZTE Jasper LTE Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Insert the spudger into the bottom left corner of the phone.
    • Use the spudger to loosen the back cover.
  2. ZTE Jasper LTE Speaker Replacement: passo 2, immagine 1 di 1
    • Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
    • Continuing to use tool, prop up the battery and remove it.
  3. ZTE Jasper LTE Speaker Replacement, Camera: passo 3, immagine 1 di 2 ZTE Jasper LTE Speaker Replacement, Camera: passo 3, immagine 2 di 2
    • Remove nine 0.8mm Phillips #00 screws.
  4. ZTE Jasper LTE Speaker Replacement: passo 4, immagine 1 di 2 ZTE Jasper LTE Speaker Replacement: passo 4, immagine 2 di 2
    • Remove the back cover by pulling upwards.
    • Removing the back cover may take a bit of force.
  5. ZTE Jasper LTE Speaker Replacement: passo 5, immagine 1 di 3 ZTE Jasper LTE Speaker Replacement: passo 5, immagine 2 di 3 ZTE Jasper LTE Speaker Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Disconnect the gold component attached to the camera by pulling upwards using the tweezers.
    • Remove the camera using the tweezers by gripping tightly around the camera and pulling upwards.
    • Camera is attached to the motherboard with adhesive. As such, you may need to use light force to remove the camera.
  6. ZTE Jasper LTE Speaker Replacement, Speaker: passo 6, immagine 1 di 2 ZTE Jasper LTE Speaker Replacement, Speaker: passo 6, immagine 2 di 2
    • Remove the speaker using the tweezers by gripping each side and pulling upwards.
    • Speaker is attached to the back case with adhesive. As such, you may need to use light force to remove the speaker.
Conclusione
Anthony Sou
Membro da: 04/22/19
391 Reputazione
4 Guide realizzate
UW Tacoma, Team S1-G1, Cardinal Spring 2019 Membro di UW Tacoma, Team S1-G1, Cardinal Spring 2019
UWT-CARDINAL-S19S1G1
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 130
