Salta al contenuto principale
ZTE Grand X Max Plus Camera Replacement
Cosa ti serve
  1. ZTE Grand X Max Plus Camera Replacement, Back Cover: passo 1, immagine 1 di 1
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Camera Replacement: passo 2, immagine 1 di 2 ZTE Grand X Max Plus Camera Replacement: passo 2, immagine 2 di 2
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Camera Replacement: passo 3, immagine 1 di 2 ZTE Grand X Max Plus Camera Replacement: passo 3, immagine 2 di 2
    • Carefully remove the cover from the phone.
  4. ZTE Grand X Max Plus Camera Replacement, Rear Camera: passo 4, immagine 1 di 2 ZTE Grand X Max Plus Camera Replacement, Rear Camera: passo 4, immagine 2 di 2
    • Remove the screws from the upper part of the phone using a screwdriver with a JIS #000 head. There are (6) six screws that should be removed.
  5. ZTE Grand X Max Plus Camera Replacement: passo 5, immagine 1 di 3 ZTE Grand X Max Plus Camera Replacement: passo 5, immagine 2 di 3 ZTE Grand X Max Plus Camera Replacement: passo 5, immagine 3 di 3
    • Use a plastic opening tool to remove the plastic piece that is protecting the motherboard.
  6. ZTE Grand X Max Plus Camera Replacement: passo 6, immagine 1 di 1
    • With a plastic opening tool, unclip the camera from the motherboard.
  7. ZTE Grand X Max Plus Camera Replacement: passo 7, immagine 1 di 3 ZTE Grand X Max Plus Camera Replacement: passo 7, immagine 2 di 3 ZTE Grand X Max Plus Camera Replacement: passo 7, immagine 3 di 3
    • After the camera is unclipped, remove it from the device.
Conclusione
USF Tampa, Team S9-G4, Remmell Fall 2017 Membro di USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 166
