Salta al contenuto principale
ZTE Grand X Max Plus Battery Replacement
Cosa ti serve
  1. ZTE Grand X Max Plus Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Battery Replacement: passo 2, immagine 1 di 2 ZTE Grand X Max Plus Battery Replacement: passo 2, immagine 2 di 2
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Battery Replacement: passo 3, immagine 1 di 2 ZTE Grand X Max Plus Battery Replacement: passo 3, immagine 2 di 2
    • Carefully remove the cover from the phone.
  4. ZTE Grand X Max Plus Battery Replacement, Battery: passo 4, immagine 1 di 2 ZTE Grand X Max Plus Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Use a plastic opening tool to pry the battery off.
    • The battery will be held down securely by glue, so it'll take quite a bit of sliding underneath to separate it from the compartment.
  5. ZTE Grand X Max Plus Battery Replacement: passo 5, immagine 1 di 3 ZTE Grand X Max Plus Battery Replacement: passo 5, immagine 2 di 3 ZTE Grand X Max Plus Battery Replacement: passo 5, immagine 3 di 3
    • Pull up the piece that is connected to the motherboard. You can pull it using your nails.
  6. ZTE Grand X Max Plus Battery Replacement: passo 6, immagine 1 di 2 ZTE Grand X Max Plus Battery Replacement: passo 6, immagine 2 di 2
    • Remove the battery.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S9-G4, Remmell Fall 2017 Membro di USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,991
