Salta al contenuto principale
ZTE Grand X Max Plus Back Cover Replacement
Cosa ti serve
  1. ZTE Grand X Max Plus Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Back Cover Replacement: passo 2, immagine 1 di 2 ZTE Grand X Max Plus Back Cover Replacement: passo 2, immagine 2 di 2
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Back Cover Replacement: passo 3, immagine 1 di 2 ZTE Grand X Max Plus Back Cover Replacement: passo 3, immagine 2 di 2
    • Carefully remove the cover from the phone.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S9-G4, Remmell Fall 2017 Membro di USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Membri
10 Guide realizzate
Un commento
There seems to be an antenna attached to the mid frame that gets stuck to the back glass on the top left. Does anyone know what this is??
Kiki Jade - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 10
Tutti i Tempi: 466
