Introduzione
The ZTE Compel features a removable and replaceable motherboard. You may need to replace the motherboard if your phone is no longer responsive and there are no signs of power. Please take all necessary precautions, such as protective gloves and eyewear, if dealing with battery corrosion.
Cosa ti serve
Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
Strumento utilizzato in questo passaggio:Tweezers$4.99
Use your tweezers to remove the black electrical tape covering connectors to the motherboard.
Use your tweezers to flip the brown clip up, and pull the ribbon connectors out of the connections.
