Introduzione
The ZTE Compel features a rechargeable lithium ion battery. You may need to replace the battery if it no longer holds a charge, if the battery is corroded, or if you are simply force restarting your phone. Please take all necessary precautions, such as protective gloves and eyewear if dealing with battery corrosion.
Cosa ti serve
Place the phone on a flat surface with the screen facing down. This will allow easy access to the removable black plastic cover on the back of the phone.
