Introduzione
An old battery can lead to increasingly shorter times between charges and reduced phone performance.
Be sure to discharge your battery as much as possible before you attempt this repair. LiPo batteries can catch fire and cause serious injury if damaged.
Removal of the battery may require heat to soften the adhesive holding the battery to the phone chassis. Do not heat the battery if you suspect that the battery has been damaged in any way.
Cosa ti serve
Turn the device on it side with the buttons away from you.
Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
Remove the one T2 screw from the side of the phone near where the SIM card tray was.
Starting at the bottom left corner of the battery, use the wide end of the spudger as a wedge to get underneath the battery.
Insert a plastic opening tool into the space created by the spudger and CAREFULLY begin to pry around the edge of the battery.
Once the battery is separated for enough from the phone, use your hands to fully remove the battery, using the wide end of the spudger to scrape off adhesive where necessary.
Altre 6 persone hanno completato questa guida.
2 Commenti
I want to clarify that in step 4 you don’t want to try to separate the back cover in the actual sim card slot but above it between the back cover and the top of the slot.
I'm not sure what or if it needs too be done I just bought a battery wanted to put in but not sure how to do it myself
