Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Follow this guide to replace the Front Camera for the ZTE Blade Spark. To get to this step, please see ZTE Blade Spark Disassembly Guide
Parti
Nessuna parte specificata.
  1. Remove Front Facing Camera:
    • Remove Front Facing Camera:
    • Locate Front Camera chipset's power connector (as shown in image).
    • Disconnect the connector.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Install replacement Front Camera component:
    • Install replacement Front Camera component:
    • Attach replacement front camera component by connecting its corresponding power connector to the device mainframe.
    • Then, set the Front Camera component properly in place as originally found.
Conclusione
To reassemble your device, follow the instructions on the ZTE Blade Spark Disassembly guide in reverse order.
Hung Vu
Membro da: 24/01/2018
632 Reputazione
5 Guide realizzate
Gateway, Team S1-G6, Johnson Spring 2018 Membro di Gateway, Team S1-G6, Johnson Spring 2018
GCC-JOHNSON-S18S1G6
2 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 48
