Salta al contenuto principale
Introduzione
Follow this guide to replace the Fingerprint Scanner for the ZTE Blade Spark. To get to this step please see ZTE Blade Spark Disassembly Guide
Parti
Nessuna parte specificata.
  1. Remove the Fingerprint Scanner:
    • Remove the Fingerprint Scanner:
    • Gently lift to disconnect the scanner's power connector from the device main frame.
  2. Now that the scanner and device back panel is detached from the back of the device , push the scanner through from the front side of the back cover.
    • Now that the scanner and device back panel is detached from the back of the device , push the scanner through from the front side of the back cover.
    • Once you have done so, set aside.
Conclusione
To reassemble your device, follow the instructions on the ZTE Blade Spark Disassembly guide in reverse order.
Hung Vu
Membro da: 24/01/2018
608 Reputazione
5 Guide realizzate
Gateway, Team S1-G6, Johnson Spring 2018 Membro di Gateway, Team S1-G6, Johnson Spring 2018
GCC-JOHNSON-S18S1G6
2 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 66
