Salta al contenuto principale
ZTE Axon 7 Back Case Replacement
Cosa ti serve
  1. ZTE Axon 7 Back Case Replacement, Back Case: passo 1, immagine 1 di 2 ZTE Axon 7 Back Case Replacement, Back Case: passo 1, immagine 2 di 2
    • Make sure the device is powered off.
    • Using the SIM Tray Removal Tool, press the pin into the hole on the SIM Tray (located on the top left of the device) to eject the tray.
  2. ZTE Axon 7 Back Case Replacement: passo 2, immagine 1 di 2 ZTE Axon 7 Back Case Replacement: passo 2, immagine 2 di 2
    • Heat the iOpener in the microwave for 15-30 seconds.
    • iOpener will be HOT! Use oven mitts if necessary.
    • Place the iOpener on top of the top and bottom speaker grills to loosen up the adhesive underneath.
  3. ZTE Axon 7 Back Case Replacement: passo 3, immagine 1 di 3 ZTE Axon 7 Back Case Replacement: passo 3, immagine 2 di 3 ZTE Axon 7 Back Case Replacement: passo 3, immagine 3 di 3
    • Use a Jimmy to pry off the top and bottom speaker grills.
    • Remove the speaker grills gently so they don't crack or break off.
  4. ZTE Axon 7 Back Case Replacement: passo 4, immagine 1 di 2 ZTE Axon 7 Back Case Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the six 3 mm screws located under the speaker grills.
    • There may be remaining adhesive covering some screws. Take time to gently scrape away the adhesive using a spudger or opening tool.
  5. ZTE Axon 7 Back Case Replacement: passo 5, immagine 1 di 2 ZTE Axon 7 Back Case Replacement: passo 5, immagine 2 di 2
    • Carefully wedge the Jimmy between the screen and aluminum back plate of the device.
    • Begin near the bottom right of the device and carefully work under the screen and slide the Jimmy up the edge of the device to remove the back case.
    • Use plastic picks to keep the display and back aluminum casing from closing as you pry along the perimeter of the phone with the Jimmy.
  6. ZTE Axon 7 Back Case Replacement: passo 6, immagine 1 di 3 ZTE Axon 7 Back Case Replacement: passo 6, immagine 2 di 3 ZTE Axon 7 Back Case Replacement: passo 6, immagine 3 di 3
    • Separate the front and back of the phone, (like a book) to open and gain access to the internal components.
    • Careful to not damage the fingerprint sensor cable attached to the motherboard from the back casing.
    • Place the tip of your opening tool under the edge of the connector, and pry the connector straight up from its socket.
    • Be very careful to pry only under the edge of the connector, and not under the socket itself. If you pry under the socket, you will separate it from the circuit board, which requires specialized microsoldering skills and equipment to repair.
    • To reconnect, align the connector carefully over its socket and press down with your fingertip—first at one side, then the other—until it clicks into place. Don't press down on the middle of the connector until it's fully aligned and seated. If misaligned the connector can be permanently damaged.
  7. ZTE Axon 7 Back Case Replacement: passo 7, immagine 1 di 1
    • The back is now completely removed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 94
