Introduzione
This is a total breakdown of the phone, and requires you to dissemble the parts pictured in order to access the screen.
Cosa ti serve
Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
Wedge the flat end of the spudger between the mid frame and the digitizer.
Gently pry the mid frame away from the rest of the phone to expose the motherboard.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use the tweezers to remove the four ribbon wires on the sides of the device.
Carefully pry the screen away from the motherboard.
Remove the remaining two ribbon wires from their connectors.
Wedge the plastic spudger between the screen and the digitizer.
Gently pry apart the screen from the digitizer.
Altre 12 persone hanno completato questa guida.
