Salta al contenuto principale
ZTE Awe Motherboard Replacement
Cosa ti serve
  1. ZTE Awe Motherboard Replacement, Remove the back cover: passo 1, immagine 1 di 1
    • Remove the back cover of the phone to expose the phone's mid-frame.
  2. ZTE Awe Motherboard Replacement, Remove battery: passo 2, immagine 1 di 1
    • Pry the battery up and out of the phone.
  3. ZTE Awe Motherboard Replacement, Detach the mid frame: passo 3, immagine 1 di 1
    • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
  4. ZTE Awe Motherboard Replacement, Separate the mid frame and the digitizer: passo 4, immagine 1 di 3 ZTE Awe Motherboard Replacement, Separate the mid frame and the digitizer: passo 4, immagine 2 di 3 ZTE Awe Motherboard Replacement, Separate the mid frame and the digitizer: passo 4, immagine 3 di 3
    • Wedge the flat end of the spudger between the mid frame and the digitizer.
  5. ZTE Awe Motherboard Replacement, Expose the motherboard: passo 5, immagine 1 di 2 ZTE Awe Motherboard Replacement, Expose the motherboard: passo 5, immagine 2 di 2
    • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
  6. ZTE Awe Motherboard Replacement, Remove the ribbon wires: passo 6, immagine 1 di 3 ZTE Awe Motherboard Replacement, Remove the ribbon wires: passo 6, immagine 2 di 3 ZTE Awe Motherboard Replacement, Remove the ribbon wires: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the tweezers to remove the four ribbon wires on the sides of the device.
  7. ZTE Awe Motherboard Replacement, Orient the motherboard: passo 7, immagine 1 di 1
    • Orient the motherboard to expose the mid frame.
  8. ZTE Awe Motherboard Replacement, Remove the connector: passo 8, immagine 1 di 3 ZTE Awe Motherboard Replacement, Remove the connector: passo 8, immagine 2 di 3 ZTE Awe Motherboard Replacement, Remove the connector: passo 8, immagine 3 di 3
    • Remove the connector to free the motherboard from the screen.
Conclusione
Altre 5 persone hanno completato questa guida.
Jennifer DeMeo
Membro da: 10/07/14
1.035 Reputazione
5 Guide realizzate
USF Tampa, Team 1-2, Leahy Fall 2014 Membro di USF Tampa, Team 1-2, Leahy Fall 2014
USFT-LEAHY-F14S1G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,908
