Introduzione
Be cautious when replacing the audio jack-- it is fragile and breaks easily. Tweezers are the optimal tool to use in order to remove and replace the audio jack.
Remove the back cover of the phone to expose the phone's mid-frame.
  • Remove the back cover of the phone to expose the phone's mid-frame.
Aggiungi Commento
Pry the battery up and out of the phone.
  • Pry the battery up and out of the phone.
Still Not Helping
Eboni - Replica
  • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws from the phone's mid frame.
Aggiungi Commento
  • Wedge the flat end of the spudger between the mid frame and the digitizer.
Aggiungi Commento
  • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
Aggiungi Commento
  • Locate the audio jack at the upper right hand corner of the device.
  • Use the metal spudger to pry the motherboard away from the device.
  • Use the metal spudger to unfasten the audio jack and pull it away from the motherboard.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Jennifer DeMeo
Membro da: 07/10/2014
960 Reputazione
5 Guide realizzate
USF Tampa, Team 1-2, Leahy Fall 2014 Membro di USF Tampa, Team 1-2, Leahy Fall 2014
USFT-LEAHY-F14S1G2
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 2,130
