Introduzione
This guide will show you how to replace the camera in case it breaks or no longer works.
Remove the back cover of the phone to expose the phone's mid-frame.
  • Remove the back cover of the phone to expose the phone's mid-frame.
Aggiungi Commento
Pry the battery up and out of the phone.
  • Pry the battery up and out of the phone.
Still Not Helping
Eboni - Replica
  • Lift the battery out of the phone.
Aggiungi Commento
  • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws along the perimeter of the phone's mid frame.
Aggiungi Commento
  • Wedge the flat end of the spudger between the mid frame and the digitizer.
Aggiungi Commento
  • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
Aggiungi Commento
  • Use the tweezers to grip the back facing camera. Gently pull until the camera is completely removed from the motherboard.
Aggiungi Commento
Conclusione
Jennifer DeMeo
Membro da: 07/10/2014
960 Reputazione
5 Guide realizzate
USF Tampa, Team 1-2, Leahy Fall 2014 Membro di USF Tampa, Team 1-2, Leahy Fall 2014
USFT-LEAHY-F14S1G2
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 535
