Salta al contenuto principale
ZD-N Plus Wireless Controller LB and RB Buttons Replacement
Cosa ti serve
  1. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
  2. ZD-N Plus Wireless Controller LB and RB Buttons Replacement: passo 2, immagine 1 di 2 ZD-N Plus Wireless Controller LB and RB Buttons Replacement: passo 2, immagine 2 di 2
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
  3. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Battery: passo 3, immagine 1 di 1
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
  4. ZD-N Plus Wireless Controller LB and RB Buttons Replacement: passo 4, immagine 1 di 2 ZD-N Plus Wireless Controller LB and RB Buttons Replacement: passo 4, immagine 2 di 2
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
  5. ZD-N Plus Wireless Controller LB and RB Buttons Replacement: passo 5, immagine 1 di 2 ZD-N Plus Wireless Controller LB and RB Buttons Replacement: passo 5, immagine 2 di 2
    • Remove the battery from the controller.
  6. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Rumble Motor: passo 6, immagine 1 di 2 ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Rumble Motor: passo 6, immagine 2 di 2
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
  7. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Motherboard: passo 7, immagine 1 di 2 ZD-N Plus Wireless Controller LB and RB Buttons Replacement, Motherboard: passo 7, immagine 2 di 2
    • Remove the three 1.2mm JIS #00 screws that hold the motherboard in place.
  8. ZD-N Plus Wireless Controller LB and RB Buttons Replacement: passo 8, immagine 1 di 1
    • Lift the motherboard out of the controller.
  9. ZD-N Plus Wireless Controller LB and RB Buttons Replacement, LB and RB Buttons: passo 9, immagine 1 di 1
    • The LB/RB buttons can be easily pulled from the top of the controller.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 615
