Salta al contenuto principale
ZCWA BR151 Wheel Replacement
Cosa ti serve
  1. ZCWA BR151 Wheel Replacement, Water Tank: passo 1, immagine 1 di 1
    • Turn off the device.
  2. ZCWA BR151 Wheel Replacement: passo 2, immagine 1 di 2 ZCWA BR151 Wheel Replacement: passo 2, immagine 2 di 2
    • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
    • Pull it out.
  3. ZCWA BR151 Wheel Replacement, Wheel: passo 3, immagine 1 di 2 ZCWA BR151 Wheel Replacement, Wheel: passo 3, immagine 2 di 2
    • Flip the device over to access the bottom panel.
    • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
    • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
  4. ZCWA BR151 Wheel Replacement: passo 4, immagine 1 di 1
    • Remove the six 6 mm screws on the bumper guards using a Phillips #0 screwdriver.
    • Remove the bumper guards by lifting them.
  5. ZCWA BR151 Wheel Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the ten 10 mm screws from the bottom plate.
  6. ZCWA BR151 Wheel Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove three 8 mm screws from the wheel plate.
  7. ZCWA BR151 Wheel Replacement: passo 7, immagine 1 di 2 ZCWA BR151 Wheel Replacement: passo 7, immagine 2 di 2
    • Carefully lift the bottom panel off of the top.
    • The top and bottom panels are attached by a set of wires. They will not fully detach at this point.
    • Gently place the bottom of the device on your workspace surface, wheels down, exposing the inner workings of the device.
  8. ZCWA BR151 Wheel Replacement: passo 8, immagine 1 di 1
    • Though optional, we recommend separating the top and bottom panels for easy access to the wheels.
    • Pinch the wire bracket that is on the top panel while pulling the bracket away.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  9. ZCWA BR151 Wheel Replacement: passo 9, immagine 1 di 3 ZCWA BR151 Wheel Replacement: passo 9, immagine 2 di 3 ZCWA BR151 Wheel Replacement: passo 9, immagine 3 di 3
    • Using a Phillips #1 screwdriver, remove the single screw to the spring.
    • Once the spring is unscrewed, slowly pull it towards you, then to the left of the spring bracket to free the spring.
  10. ZCWA BR151 Wheel Replacement: passo 10, immagine 1 di 2 ZCWA BR151 Wheel Replacement: passo 10, immagine 2 di 2
    • The wheel's motor is still attached to the motherboard of the device. Locate the wheel's wiring and the port connector on the motherboard.
    • Pinch the silver brackets and pull the wire casing away from the motherboard.
    • Remove the wheel from the vacuum.
    • Repeat Steps 6-10 to replace the wheel on the opposite side.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 77
