Salta al contenuto principale
ZCWA BR151 Water Filter Replacement
Cosa ti serve
  1. ZCWA BR151 Water Filter Replacement, Water Tank: passo 1, immagine 1 di 1
    • Turn off the device.
  2. ZCWA BR151 Water Filter Replacement: passo 2, immagine 1 di 2 ZCWA BR151 Water Filter Replacement: passo 2, immagine 2 di 2
    • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
    • Pull it out.
  3. ZCWA BR151 Water Filter Replacement, Water Filter: passo 3, immagine 1 di 3 ZCWA BR151 Water Filter Replacement, Water Filter: passo 3, immagine 2 di 3 ZCWA BR151 Water Filter Replacement, Water Filter: passo 3, immagine 3 di 3
    • Remove the filter holders, on the bottom of the water tank, one at a time by maneuvering the spudger under the flaps of the filter holders.
    • Use the spudger to lift enough of the flap up to pinch it between two fingers.
    • Pull the flap up while pinching it to dislodge the filter holder from the water tank.
  4. ZCWA BR151 Water Filter Replacement: passo 4, immagine 1 di 3 ZCWA BR151 Water Filter Replacement: passo 4, immagine 2 di 3 ZCWA BR151 Water Filter Replacement: passo 4, immagine 3 di 3
    • To extract the cotton filters, push the flaps of the filter holders down.
    • Use the tweezers to pull out the filter.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 32
