Salta al contenuto principale
ZCWA BR151 Velcro Replacement
Cosa ti serve
  1. ZCWA BR151 Velcro Replacement, Velcro: passo 1, immagine 1 di 2 ZCWA BR151 Velcro Replacement, Velcro: passo 1, immagine 2 di 2
    • Turn off the device.
    • Flip the device over to access the bottom panel.
    • Remove the cloth mop covering by lifting it from the velcro on the plastic mop attachment.
    • Remove the plastic mop attachment by placing your fingers underneath and prying it up.
  2. ZCWA BR151 Velcro Replacement: passo 2, immagine 1 di 1
    • Use a Jimmy to get underneath the velcro until you are able to push it up enough to grab.
  3. ZCWA BR151 Velcro Replacement: passo 3, immagine 1 di 1
    • Use tweezers to peel off the rest of the velcro.
    • If necessary, use the spudger to remove more of the adhesive beneath the velcro.
    • You will need four velcro strips. Cut out two, 1-inch long strips of velcro.
    • Cut an additional two, 3-inch long strips.
    • If your velcro strips already have an adhesive back, simply attach them to the top of the mop bracket.
    • If you are using a hot glue gun to attach your velcro, place a small section of glue where you want the velcro to go, then carefully press your piece down.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 49
