Salta al contenuto principale
ZCWA BR151 Battery Replacement
Cosa ti serve
  1. ZCWA BR151 Battery Replacement, Water Tank: passo 1, immagine 1 di 1
    • Turn off the device.
  2. ZCWA BR151 Battery Replacement: passo 2, immagine 1 di 2 ZCWA BR151 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
    • Pull it out.
  3. ZCWA BR151 Battery Replacement, Battery: passo 3, immagine 1 di 2 ZCWA BR151 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Flip the device over to access the panels on the back.
    • Rotate the device to where the battery panel is closest to you.
    • Using a Phillips #1 screwdriver, remove the two 10 mm screws from the battery panel.
  4. ZCWA BR151 Battery Replacement: passo 4, immagine 1 di 2 ZCWA BR151 Battery Replacement: passo 4, immagine 2 di 2
    • From the opposite end of the battery wires, use an opening tool to pry the battery out.
    • Do not use metal objects to pry out the battery.
    • You may need to rotate the device depending on your hand prominence.
  5. ZCWA BR151 Battery Replacement: passo 5, immagine 1 di 1
    • Peel off the electrical tape that wraps around the battery's wire connectors.
  6. ZCWA BR151 Battery Replacement: passo 6, immagine 1 di 2 ZCWA BR151 Battery Replacement: passo 6, immagine 2 di 2
    • Pinch the two lock mechanisms on the wire connectors while pulling them apart.
    • Set aside the old battery to dispose of later.
    • Batteries can be safely disposed of at your local recycling center with the help of a professional.
Conclusione
Un commento
Ok cool I hope it works
Blueobear - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 35
Tutti i Tempi: 117
