Salta al contenuto principale
Yuneec Typhoon H Plus Propeller Replacement
  1. Yuneec Typhoon H Plus Propeller Replacement, Propeller: passo 1, immagine 1 di 1
    • Locate the broken propeller and figure out if it is a A-propeller or B-propeller.
    • An A-propeller will have a black button in the center and an A imprinted on the propeller.
    • A B-propeller will have a white button and a B imprinted on the propeller.
    • Though the A and B propellers are different the steps to replace one are the same.
  2. Yuneec Typhoon H Plus Propeller Replacement: passo 2, immagine 1 di 1
    • Press down on the button firmly.
  3. Yuneec Typhoon H Plus Propeller Replacement: passo 3, immagine 1 di 2 Yuneec Typhoon H Plus Propeller Replacement: passo 3, immagine 2 di 2
    • Hold the base of the propeller with your pointer finger.
    • Make sure to continue to hold the button down. Rotate the propeller counter-clockwise, holding the base steady.
    • Lift the propeller off the drone.
Conclusione
Brice Black
Membro da: 01/23/20
557 Reputazione
4 Guide realizzate
Cal Poly, Team S2-G1, White Winter 2020 Membro di Cal Poly, Team S2-G1, White Winter 2020
CPSU-WHITE-W20S2G1
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 204
