Salta al contenuto principale
Yuneec Typhoon H Landing Gear Replacement
Cosa ti serve
  1. Yuneec Typhoon H Landing Gear  Replacement, Landing Gear: passo 1, immagine 1 di 2 Yuneec Typhoon H Landing Gear  Replacement, Landing Gear: passo 1, immagine 2 di 2
    • Lift all drone arms up so you can access the landing gear easily.
  2. Yuneec Typhoon H Landing Gear  Replacement: passo 2, immagine 1 di 3 Yuneec Typhoon H Landing Gear  Replacement: passo 2, immagine 2 di 3 Yuneec Typhoon H Landing Gear  Replacement: passo 2, immagine 3 di 3
    • Unscrew the 16.9 mm screw at the top of the landing leg with a Phillips #00 screwdriver.
    • Make sure the screw head is not stripped in the process.
    • If stripped, the whole leg, including the internal sensors, will need to be replaced.
  3. Yuneec Typhoon H Landing Gear  Replacement: passo 3, immagine 1 di 1
    • Pull the landing leg out slowly and remove it from the device.
Conclusione
Your Yuneec Typhoon H should now be ready to fly safely again.
Cal Poly, Team S22-G3, Maness Spring 2018 Membro di Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,094
