Salta al contenuto principale
Yuneec Typhoon H Gimbal Bushing Reattachment
Cosa ti serve
  1. Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: passo 1, immagine 1 di 2 Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: passo 1, immagine 2 di 2
    • In order to repair the camera and camera gimbal, remove the camera configuration from the body of the drone.
    • Pull up on the tab connected to the camera configuration and slide the entire apparatus off.
  2. Yuneec Typhoon H Gimbal Bushing Reattachment: passo 2, immagine 1 di 3 Yuneec Typhoon H Gimbal Bushing Reattachment: passo 2, immagine 2 di 3 Yuneec Typhoon H Gimbal Bushing Reattachment: passo 2, immagine 3 di 3
    • Put the gimbal bushings (the rubber balls) back into the plastic alignment mounts.
    • The circle that is separated from the main body of the bushing should then be inserted into the hole.
    • When pushing these bushings back into place, it is smart to use a skinny tool or toothpick.
Conclusione
To reassemble your device, simply slide the camera mount back onto the bottom of the drone.
Altre 2 persone hanno completato questa guida.
Jake Breul
Membro da: 04/16/18
127 Reputazione
1 Guida realizzata
Cal Poly, Team S22-G3, Maness Spring 2018 Membro di Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 Membri
5 Guide realizzate
3 Commenti
Camera not getting power after crash.
Don - Replica
Crashed drone and camera not getting power anymore. Nothing appears to be broken.
Don - Replica
Did steps. Bushings ok. Camera still won't communicate.
vickiesamus - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,605
