Salta al contenuto principale
Yuneec ST10 Plus Battery Replacement
  1. Yuneec ST10 Plus Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the controller upside down to access the battery compartment.
    • Grab the compartment door and pull down.
  2. Yuneec ST10 Plus Battery Replacement: passo 2, immagine 1 di 1
    • Gently lift the blue tab connected to the battery in order to remove the battery from its housing.
  3. Yuneec ST10 Plus Battery Replacement: passo 3, immagine 1 di 3 Yuneec ST10 Plus Battery Replacement: passo 3, immagine 2 di 3 Yuneec ST10 Plus Battery Replacement: passo 3, immagine 3 di 3
    • To disconnect the battery from the remote, grab the red and black connectors.
    • Pull gently on connectors until they disconnect.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 165
