Salta al contenuto principale
Yuneec Breeze 4K Motherboard Replacement
Cosa ti serve
  1. Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: passo 1, immagine 1 di 2 Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: passo 1, immagine 2 di 2
    • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
    • Flip over the drone so that the propellers are facing down and the camera is facing up.
  2. Yuneec Breeze 4K Motherboard Replacement: passo 2, immagine 1 di 3 Yuneec Breeze 4K Motherboard Replacement: passo 2, immagine 2 di 3 Yuneec Breeze 4K Motherboard Replacement: passo 2, immagine 3 di 3
    • Grip the cover that covers the rest of the wires, and give it a slight pull to remove it.
  3. Yuneec Breeze 4K Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the 4 rubber plugs that hold the drone and its internal parts together.
    • These plugs can be located in each corner of the drone, and are white.
  4. Yuneec Breeze 4K Motherboard Replacement: passo 4, immagine 1 di 1
    • Unplug the four cables that are connected on the top face of the frame.
  5. Yuneec Breeze 4K Motherboard Replacement: passo 5, immagine 1 di 2 Yuneec Breeze 4K Motherboard Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • The rest of the wires that are still connected can be unplugged.
    • Using a pair of tweezers they can be unplugged.
  6. Yuneec Breeze 4K Motherboard Replacement: passo 6, immagine 1 di 3 Yuneec Breeze 4K Motherboard Replacement: passo 6, immagine 2 di 3 Yuneec Breeze 4K Motherboard Replacement: passo 6, immagine 3 di 3
    • Lift up or tilt entire frame and mother board and unplug all the wires.
  7. Yuneec Breeze 4K Motherboard Replacement: passo 7, immagine 1 di 3 Yuneec Breeze 4K Motherboard Replacement: passo 7, immagine 2 di 3 Yuneec Breeze 4K Motherboard Replacement: passo 7, immagine 3 di 3
    • The battery connector has two wires connected to a plug in with two little screws.
    • Unscrew the two screws and pull it apart using a small tweezers.
  8. Yuneec Breeze 4K Motherboard Replacement: passo 8, immagine 1 di 1
    • Flip over the frame and mother board and unscrew the mother board.
    • There are four screws on each corner of the mother board.
  9. Yuneec Breeze 4K Motherboard Replacement: passo 9, immagine 1 di 2 Yuneec Breeze 4K Motherboard Replacement: passo 9, immagine 2 di 2
    • After the screws are out, the motherboard can be pulled out softly with hands.
    • Remove the motherboard from the device.
Conclusione
Altre 5 persone hanno completato questa guida.
Ryanne Millis
Membro da: 10/04/18
318 Reputazione
1 Guida realizzata
UW Stout, Team S6-G5, Ogden Fall 2018 Membro di UW Stout, Team S6-G5, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G5
4 Membri
4 Guide realizzate
Un commento
Excellent step by step instructions.
paul_courville - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,042
