Salta al contenuto principale
Yujin Robot iCLEBO Arte Filter Replacement
  1. Yujin Robot iCLEBO Arte Filter Replacement, Dust Bin: passo 1, immagine 1 di 1
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Filter Replacement: passo 2, immagine 1 di 2 Yujin Robot iCLEBO Arte Filter Replacement: passo 2, immagine 2 di 2
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
  3. Yujin Robot iCLEBO Arte Filter Replacement, Filter: passo 3, immagine 1 di 1
    • Push the yellow tab releasing the filter harness.
  4. Yujin Robot iCLEBO Arte Filter Replacement: passo 4, immagine 1 di 1
    • Replace or clean filter under a stream of water. When reinserting filter, make sure the filter's cut corner is in the correct corner.
Conclusione
To finish reassembling your device, follow these instructions in reverse order.
Nathan Clark
Membro da: 02/28/17
101 Reputazione
1 Guida realizzata
USF Tampa, Team S2-G3, Nance Spring 2017 Membro di USF Tampa, Team S2-G3, Nance Spring 2017
USFT-NANCE-S17S2G3
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 308
