Salta al contenuto principale
Yujin Robot iCLEBO Arte Dust Bin Replacement
Cosa ti serve
  1. Yujin Robot iCLEBO Arte Dust Bin Replacement, Dust Bin: passo 1, immagine 1 di 1
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Dust Bin Replacement: passo 2, immagine 1 di 2 Yujin Robot iCLEBO Arte Dust Bin Replacement: passo 2, immagine 2 di 2
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
Conclusione
To reassemble the dust bin, follow these instructions in reverse order.
Trent Treiber
Membro da: 02/28/17
204 Reputazione
2 Guide realizzate
USF Tampa, Team S2-G3, Nance Spring 2017 Membro di USF Tampa, Team S2-G3, Nance Spring 2017
USFT-NANCE-S17S2G3
4 Membri
14 Guide realizzate
3 Commenti
My machine says C3 even though the dust bin is successfully in place. Now what? Works fine on hardwood floors.
Amy Abbiatti - Replica
C3 error even though dustbin is installed correctly. Works fine on hardwood floors. Now what?
I also get C3 error when dustbin is clean and installed correctly - now what?
Philip Melese - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,078
