Introduzione
This video will show how to use the MapKeyboard software to map a broken key to another lesser used key. This will be useful if you have a keyboard with a broken key that cannot be replaced or repaired, but still want to continue to use that keyboard. This will not be a perfect fix, so for a more permanent solution, visit our How to Replace Keys on a Keyboard Guide.
1. When one of your keyboard's keys is broken, you don't want to spend a lot of money to replace the entire keyboard because of one key
2. You can use a software called "MapKeyboard"
3. Start the software and select the key you will use to replace the broken key
4. Select "ReMap selected key to" and select the broken key "G"
5. Click on "Save layout" and the laptop will restart
6. After restarting, you will find that the key you set can be typed with “G” so that you can continue to use your keyboard without changing it
7. If you want to restore the layout of the keyboard, you can start the software again, click on "Reset keyboard layout"
8.After the restart, it will be restored
