Salta al contenuto principale
Yoton YB02 Motion Sensor Replacement
Cosa ti serve
  1. Yoton YB02 Motion Sensor Replacement, Motion Sensor: passo 1, immagine 1 di 2 Yoton YB02 Motion Sensor Replacement, Motion Sensor: passo 1, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the single 7 mm screw from the back of the panel from the camera.
  2. Yoton YB02 Motion Sensor Replacement: passo 2, immagine 1 di 2 Yoton YB02 Motion Sensor Replacement: passo 2, immagine 2 di 2
    • Use a metal spudger to pry off the back panel from the camera.
    • It is recommended to pry at the edges of the panel and run through the edge of the panel.
  3. Yoton YB02 Motion Sensor Replacement: passo 3, immagine 1 di 3 Yoton YB02 Motion Sensor Replacement: passo 3, immagine 2 di 3 Yoton YB02 Motion Sensor Replacement: passo 3, immagine 3 di 3
    • With the soldering iron, desolder the pins holding the camera in place onto the motherboard on the other side of the motherboard.
    • Carefully pry off the camera unit, including the motion sensor, with your hands.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 35
