Salta al contenuto principale
Yoton YB02 Monitor Speaker Replacement
Cosa ti serve
  1. Yoton YB02 Monitor Speaker Replacement, Monitor Speaker: passo 1, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the four 7 mm screws from the back panel of the monitor.
  2. Yoton YB02 Monitor Speaker Replacement: passo 2, immagine 1 di 2 Yoton YB02 Monitor Speaker Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to separate the back panel from the monitor.
    • It is recommended to start from a corner, and run the tool along the edge of the panel.
  3. Yoton YB02 Monitor Speaker Replacement: passo 3, immagine 1 di 2 Yoton YB02 Monitor Speaker Replacement: passo 3, immagine 2 di 2
    • Using the plastic tool, disconnect the cables connecting the speaker to the motherboard.
  4. Yoton YB02 Monitor Speaker Replacement: passo 4, immagine 1 di 2 Yoton YB02 Monitor Speaker Replacement: passo 4, immagine 2 di 2
    • Using the metal spudger, pry off the speaker from the back panel.
    • It is recommended to scrape off excess glue holding the speaker to the panel with the spudger.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 39
