Salta al contenuto principale
Yoton YB02 Camera Stand Speaker Replacement
Cosa ti serve
  1. Yoton YB02 Camera Stand Speaker Replacement, Camera Stand Speaker: passo 1, immagine 1 di 2 Yoton YB02 Camera Stand Speaker Replacement, Camera Stand Speaker: passo 1, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the single 7 mm screw from the back of the panel from the camera.
  2. Yoton YB02 Camera Stand Speaker Replacement: passo 2, immagine 1 di 2 Yoton YB02 Camera Stand Speaker Replacement: passo 2, immagine 2 di 2
    • Use a metal spudger to pry off the back panel from the camera.
    • It is recommended to pry at the edges of the panel and run through the edge of the panel.
  3. Yoton YB02 Camera Stand Speaker Replacement: passo 3, immagine 1 di 1
    • Carefully move the motherboard out of the way to access the camera speaker.
  4. Yoton YB02 Camera Stand Speaker Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to remove the camera speaker from the panel.
    • It is recommended to remove or scrape off the excess glue holding the camera in place.
  5. Yoton YB02 Camera Stand Speaker Replacement: passo 5, immagine 1 di 3 Yoton YB02 Camera Stand Speaker Replacement: passo 5, immagine 2 di 3 Yoton YB02 Camera Stand Speaker Replacement: passo 5, immagine 3 di 3
    • With the plastic opening tool, detach the cable from the speaker to the motherboard at the clips.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 26
