Salta al contenuto principale
Yamaha FG-425 Guitar String Replacement
Cosa ti serve
  1. Yamaha FG-425 Guitar String Replacement, Guitar String: passo 1, immagine 1 di 3 Yamaha FG-425 Guitar String Replacement, Guitar String: passo 1, immagine 2 di 3 Yamaha FG-425 Guitar String Replacement, Guitar String: passo 1, immagine 3 di 3
    • Turn the tuning peg clockwise using the All-In-1 Restringing Tool’s peg winder to loosen the tension of the strings.
    • Unwind the string from the tuning post and remove the string.
    • Caution: Be careful when removing the string from the tuning post because you may hurt your fingers while doing so.
  2. Yamaha FG-425 Guitar String Replacement: passo 2, immagine 1 di 2 Yamaha FG-425 Guitar String Replacement: passo 2, immagine 2 di 2
    • Use the pin remover in the All-In-1 Restringing Tool to remove the pin from the bridge
    • Remove the string from the bridge hole.
  3. Yamaha FG-425 Guitar String Replacement: passo 3, immagine 1 di 2 Yamaha FG-425 Guitar String Replacement: passo 3, immagine 2 di 2
    • Bend the string end on the string ball.
    • Place the string into the bridge hole.
  4. Yamaha FG-425 Guitar String Replacement: passo 4, immagine 1 di 3 Yamaha FG-425 Guitar String Replacement: passo 4, immagine 2 di 3 Yamaha FG-425 Guitar String Replacement: passo 4, immagine 3 di 3
    • Place the bridge pin into the bridge hole.
    • Gently pull the string while pushing the pin into the hole.
  5. Yamaha FG-425 Guitar String Replacement: passo 5, immagine 1 di 2 Yamaha FG-425 Guitar String Replacement: passo 5, immagine 2 di 2
    • Insert the string through the tuning post hole.
    • Pull the string about half an inch or an inch through the tuning post.
    • Ensure that the string is lined up with the nut.
  6. Yamaha FG-425 Guitar String Replacement: passo 6, immagine 1 di 1
    • Use the All-In-1 Restringing Tool's peg winder to turn the tuning peg counterclockwise to slightly tighten the strings.
  7. Yamaha FG-425 Guitar String Replacement: passo 7, immagine 1 di 1
    • Cut any excess strings on the tuning post using the All-In-1 Restringing Tool’s clippers.
Linea Traguardo
Nicole Francheska Letigio
Membro da: 01/18/21
207 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 426
