Salta al contenuto principale
XtremeMac Luna Dissasembly
Cosa ti serve
  1. XtremeMac Luna Dissasembly, Bottom Panel: passo 1, immagine 1 di 3 XtremeMac Luna Dissasembly, Bottom Panel: passo 1, immagine 2 di 3 XtremeMac Luna Dissasembly, Bottom Panel: passo 1, immagine 3 di 3
    • Flip the device over so that the batteries are closest to you.
    • Remove the battery lid by pressing the battery cover's tab and pulling it away from the device.
    • Push the battery against the spring and lift it out of the casing.
    • Repeat with the other battery.
  2. XtremeMac Luna Dissasembly: passo 2, immagine 1 di 1
    • Unscrew all eight 12mm Phillips head screws with a Philips #1 screwdriver.
    • The iFixit 26 bit screwdriver kit will not reach the screws. Make sure to use a screwdriver that is thin enough to not get stuck in the screw holes.
  3. XtremeMac Luna Dissasembly: passo 3, immagine 1 di 2 XtremeMac Luna Dissasembly: passo 3, immagine 2 di 2
    • Flip the Luna back over so that the buttons are facing upward and the LCD screen is facing you.
    • Gently tilt the lid back 45 degrees so that the inside is exposed.
    • Be mindful of the wires inside of the Luna. It is easy to break a connection if a wire gets caught.
Conclusione
Daniel Johnson
Membro da: 04/14/13
1 Reputazione
1 Guida realizzata
Cal Poly, Team 3-47, Amido Spring 2013 Membro di Cal Poly, Team 3-47, Amido Spring 2013
CPSU-AMIDO-S13S3G47
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 410
