Salta al contenuto principale
Xiaomi Yi Front Panel Replacement
Cosa ti serve
  1. Xiaomi Yi Front Panel Replacement, Battery: passo 1, immagine 1 di 2 Xiaomi Yi Front Panel Replacement, Battery: passo 1, immagine 2 di 2
    • Push the battery door switch to the left.
    • Lift the battery door up.
  2. Xiaomi Yi Front Panel Replacement: passo 2, immagine 1 di 3 Xiaomi Yi Front Panel Replacement: passo 2, immagine 2 di 3 Xiaomi Yi Front Panel Replacement: passo 2, immagine 3 di 3
    • Lift the battery tab up.
    • Remove the battery by pulling the removal tab.
  3. Xiaomi Yi Front Panel Replacement, Front Panel: passo 3, immagine 1 di 2 Xiaomi Yi Front Panel Replacement, Front Panel: passo 3, immagine 2 di 2
    • Introduce the plastic opening tool into any of the sides of the camera.
    • Pry with the plastic opening tool at the seam between the front and the back panel.
  4. Xiaomi Yi Front Panel Replacement: passo 4, immagine 1 di 3 Xiaomi Yi Front Panel Replacement: passo 4, immagine 2 di 3 Xiaomi Yi Front Panel Replacement: passo 4, immagine 3 di 3
    • Slide prying tool along the seam until front panel is fully separated from the back panel.
Conclusione
Altre 5 persone hanno completato questa guida.
USF Tampa, Team 15-5, Blackwell Fall 2015 Membro di USF Tampa, Team 15-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G5
3 Membri
10 Guide realizzate
3 Commenti
Where do you get a spare front panel, the small plastic hooks break easily
ltkipras - Replica
I would like to know too because i had a crash and i lost the ring that goes around the lens.
fabiocastroam -
For what is the black Strip with the gold plated contact on the front panel? Is that a check for installated front panel, and can i fake them for an replacement panel?
shguro - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,823
