Introduzione
If your screen is unresponsive, has dead pixels, or is cracked, this guide will show you how to replace it. Removing the screen requires use of a heat gun to melt the adhesive holding the screen to the frame.
Cosa ti serve
Insert the plastic opening tool between the charging port and the rear case.
Pry the end of the rear case up from the charging port.
Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
Run the plastic opening tool along the seam.
Pry up the midframe with the plastic opening tool.
Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
Locate the charging port panel at the bottom of the device.
Remove the 2.9 mm Phillips #00 screws on the sides of the panel.
Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
Use tweezers to pull the ribbon cable out of the ZIF connector.
Remove the front-facing camera from the motherboard.
Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
Use tweezers to pull out the rubber proximity sensor from the top left of the frame
Altre 6 persone hanno completato questa guida.
