Salta al contenuto principale
Xiaomi Redmi Note 3 Disassembly Guide
Cosa ti serve
  1. Xiaomi Redmi Note 3 Disassembly Guide, Eject the Sim Card Tray: passo 1, immagine 1 di 2 Xiaomi Redmi Note 3 Disassembly Guide, Eject the Sim Card Tray: passo 1, immagine 2 di 2
    • Locate the sim card tray at the right side of the phone
    • Insert the metal needle sim tool into the tray hole to eject the tray and pull it out
  2. Xiaomi Redmi Note 3 Disassembly Guide, Remove Phone Panel: passo 2, immagine 1 di 1
    • Insert your thumb in between the back panel and the front of phone and slowly follow along the edges to separate the two pieces
  3. Xiaomi Redmi Note 3 Disassembly Guide, Disconnect the Connector: passo 3, immagine 1 di 1
    • Remove the plastic connector that links the battery with the motherboard by gently prying the ends of the connector from each side of the phone
  4. Xiaomi Redmi Note 3 Disassembly Guide, Begin Battery Removal: passo 4, immagine 1 di 1
    • Pull the black tab at the top left of the battery to disconnect the battery from the system
  5. Xiaomi Redmi Note 3 Disassembly Guide, Remove Battery: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Wedge the tweezers under the battery to lift it up
    • Remove as much as adhesive as needed to lift the battery from phone using tweezers or fingers
    • Adhesive that binds the battery to the phone can be strong and this may require a little bit of effort to remove the battery
  6. Xiaomi Redmi Note 3 Disassembly Guide, Unscrew Speaker: passo 6, immagine 1 di 1
    • Use the screwdriver to unscrew the speaker at the bottom back of the phone. There are five screws around the edges of the speaker
  7. Xiaomi Redmi Note 3 Disassembly Guide, Detach Speaker: passo 7, immagine 1 di 1
    • Remove the loud speaker cover using the tweezers to expose the daughterboard
  8. Xiaomi Redmi Note 3 Disassembly Guide, Remove Daughterboard: passo 8, immagine 1 di 2 Xiaomi Redmi Note 3 Disassembly Guide, Remove Daughterboard: passo 8, immagine 2 di 2
    • Remove the two gold tabs on the two top corners of the daughterboard
    • Pry the daughterboard open with the tweezers or pull it out using your fingers
    • There is a heat shield underneath the daughter board and it can get hot from charging the phone so make sure you don’t touch it
  9. Xiaomi Redmi Note 3 Disassembly Guide, Begin to Remove Camera: passo 9, immagine 1 di 1
    • Unscrew the four screws at the top of the motherboard and pop up the top cover
    • One screw might by disguised by a sticker so locate that and remove the sticker as well
    • Pulling the top cover without removing all the screws might damage the motherboard
  10. Xiaomi Redmi Note 3 Disassembly Guide, Remove Camera Cushion: passo 10, immagine 1 di 1
    • Remove the rubber cover that’s containing the camera
  11. Xiaomi Redmi Note 3 Disassembly Guide, Remove Front Camera Protector: passo 11, immagine 1 di 1
    • Pull the tab that’s holding the front camera to remove the camera protector
    • To keep the camera from damage hold the camera from the corner and not from the middle of it
  12. Xiaomi Redmi Note 3 Disassembly Guide, Remove Camera: passo 12, immagine 1 di 1
    • Pull out the front camera using tweezers or your fingers
  13. Xiaomi Redmi Note 3 Disassembly Guide, Remove Motherboard Connectors: passo 13, immagine 1 di 1
    • Remove the five connectors of the motherboard using tweezers or your fingers
  14. Xiaomi Redmi Note 3 Disassembly Guide, Remove Motherboard: passo 14, immagine 1 di 1
    • Remove the remaining four screws as your work down to the bottom to loosen the motherboard
  15. Xiaomi Redmi Note 3 Disassembly Guide, Admire Disassembled Phone: passo 15, immagine 1 di 1
    • Congrats -- You disassembled the Xiaomi Redmi Note 3!
Conclusione
Meaghan Owens
Membro da: 06/23/23
241 Reputazione
1 Guida realizzata
1Commento della guida
Memory ic problem
Sure - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 47
Tutti i Tempi: 1,538
