Salta al contenuto principale
Xiaomi Redmi 2 Front Speaker Replacement
Cosa ti serve
  1. Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: passo 1, immagine 1 di 2 Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: passo 1, immagine 2 di 2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Front Speaker Replacement: passo 2, immagine 1 di 1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Front Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Front Speaker Replacement: passo 4, immagine 1 di 1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Front Speaker Replacement: passo 5, immagine 1 di 1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Front Speaker Replacement: passo 6, immagine 1 di 2 Xiaomi Redmi 2 Front Speaker Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Front Speaker Replacement: passo 7, immagine 1 di 2 Xiaomi Redmi 2 Front Speaker Replacement: passo 7, immagine 2 di 2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Front Speaker Replacement: passo 8, immagine 1 di 2 Xiaomi Redmi 2 Front Speaker Replacement: passo 8, immagine 2 di 2
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Front Speaker Replacement: passo 9, immagine 1 di 2 Xiaomi Redmi 2 Front Speaker Replacement: passo 9, immagine 2 di 2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Front Speaker Replacement: passo 10, immagine 1 di 2 Xiaomi Redmi 2 Front Speaker Replacement: passo 10, immagine 2 di 2
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Front Speaker Replacement: passo 11, immagine 1 di 1
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 Front Speaker Replacement, Front Speaker: passo 12, immagine 1 di 1
    • Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
  13. Xiaomi Redmi 2 Front Speaker Replacement: passo 13, immagine 1 di 1
    • Using your fingers, gently lift the front speaker from the screen assembly.
Conclusione
Altre 7 persone hanno completato questa guida.
Alicia Brenner
Membro da: 10/01/15
3.539 Reputazione
5 Guide realizzate
USF Tampa, Team 1-3, Leahy Fall 2015 Membro di USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
2 Membri
5 Guide realizzate
4 Commenti
How can I remove the contact from the speaker? I bought a new screen and it hasn't this contact and the vibracall module, but the second I know how to remove from the old screen.
brunofichos - Replica
sorry about my english, I want to say "back speaker's contact" not "contact from the speaker". Thanks
brunofichos -
You know how to remove the speaker contacts from the rear speaker. It's stuck in the redmi2pro frame. I bought an LCD touch frame and need to move the components to the new one.
afreitasleonardo - Replica
Rademi 2 front Speakers problem
Amol Surve - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 7,098
