Salta al contenuto principale
Xiaomi Mi Pad Rear Case Assembly Replacement
Cosa ti serve
  1. Xiaomi Mi Pad Rear Case Assembly Replacement, Rear Case Assembly: passo 1, immagine 1 di 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Rear Case Assembly Replacement: passo 2, immagine 1 di 2 Xiaomi Mi Pad Rear Case Assembly Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 12-5, Blackwell Fall 2015 Membro di USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 59
Tutti i Tempi: 1,518
