Salta al contenuto principale
Xiaomi Mi Pad Rear Camera Replacement
Cosa ti serve
  1. Xiaomi Mi Pad Rear Camera Replacement, Rear Case Assembly: passo 1, immagine 1 di 1
    • Remove the micro SD card slot from the left side of the device using either the metal pin included with the device or a SIM card eject tool.
  2. Xiaomi Mi Pad Rear Camera Replacement: passo 2, immagine 1 di 2 Xiaomi Mi Pad Rear Camera Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool and/or opening pick to gently pry the back panel away from the device. Work your way around the device, slowly increasing the gap.
    • The back panel has small clips and light adhesive that easily releases from the device.
  3. Xiaomi Mi Pad Rear Camera Replacement, Rear Camera: passo 3, immagine 1 di 2 Xiaomi Mi Pad Rear Camera Replacement, Rear Camera: passo 3, immagine 2 di 2
    • Remove the twelve 3.0 mm Phillips #000 screws on the upper cover of the device.
  4. Xiaomi Mi Pad Rear Camera Replacement: passo 4, immagine 1 di 1
    • Remove the upper cover from the device.
  5. Xiaomi Mi Pad Rear Camera Replacement: passo 5, immagine 1 di 1
    • Use a plastic opening tool to disconnect the rear-facing camera from the motherboard.
  6. Xiaomi Mi Pad Rear Camera Replacement: passo 6, immagine 1 di 1
    • Carefully remove the rear camera from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 12-5, Blackwell Fall 2015 Membro di USF Tampa, Team 12-5, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G5
3 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 10
Tutti i Tempi: 784
