Salta al contenuto principale
Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
Panoramica Video
Xiaomi Redmi K20 Pro Screen Replacement
  1. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement, Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 1, immagine 1 di 3 Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement, Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 1, immagine 2 di 3 Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement, Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 1, immagine 3 di 3
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 2, immagine 1 di 2 Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 2, immagine 2 di 2
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
  3. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 3, immagine 1 di 2 Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
  4. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 4, immagine 1 di 2 Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 4, immagine 2 di 2
    • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
  5. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 5, immagine 1 di 2 Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 5, immagine 2 di 2
    • Remove the phone's back cover.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
  6. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 6, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove the eleven 3.5 mm screws on the top midframe.
    • Use a Phillips #000 screwdriver to remove one 2 mm screw.
  7. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 7, immagine 1 di 1
    • Remove the phone's motherboard protective bracket.
  8. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 8, immagine 1 di 1
    • Remove the plastic assembly covering the camera's lenses.
  9. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 9, immagine 1 di 1
    • Use the flat end of a spudger to disconnect the power flex cable and the display flex cable.
  10. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 10, immagine 1 di 1
    • Use a Phillips #000 screwdriver to remove eight 3.5 mm screws from the bottom midframe.
  11. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 11, immagine 1 di 2 Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 11, immagine 2 di 2
    • Insert the flat end of a spudger underneath the sub-board cover.
    • Pry upwards on the sub-board cover until it pops out.
    • Remove the sub-board cover.
  12. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 12, immagine 1 di 2 Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 12, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the display flex cable.
    • Remove the display flex cable.
  13. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 13, immagine 1 di 2 Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 13, immagine 2 di 2
    • Use a heat gun to lightly heat the edges of the phone's screen to soften the adhesive that connects the display to the rest of the frame.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • An iFixit iOpener, hair dryer, or hot plate can also be used to heat the edges. Follow the iOpener Heating guide for instructions on using the iOpener.
  14. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 14, immagine 1 di 3 Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 14, immagine 2 di 3 Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 14, immagine 3 di 3
    • Insert a plastic card, Jimmy tool, or opening pick under the edge of the display.
  15. Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 15, immagine 1 di 2 Xiaomi Mi 9T Pro/Redmi K20 Pro Screen Replacement: passo 15, immagine 2 di 2
    • Apply a suction cup to the lower portion of the phone's display.
    • Pull firmly upwards on the suction cup to remove the screen.
Conclusione
Selena
Membro da: 12/15/19
2.767 Reputazione
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,165
