Introduzione
Use this guide to remove or replace a broken rear camera glass in your Xiaomi Mi 9.
You’ll need replacement adhesive to reattach components when reassembling the device.
Cosa ti serve
Before you begin, switch off your phone.
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner of the phone.
Insert a fourth opening pick under the top left corner of the rear glass.
Slide the opening pick along the top to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Be very careful at this point not to raise the cover too much, at the slightest bending the glass shatters. It just happened to me :(
Remove the ten Phillips #00 screws (3 mm length) that secure the motherboard cover.
Note, the Explorer/Transparent edition does not use phillips #00 screws.
It uses 0.8mm star screws(P2 Pentalobe in the iFixIt store)
Thanks for mentioning Jason!
Use the flat end of a spudger to pry up and disconnect the sensor cable of the rear camera glass.
Remove the rear camera glass.
Can we replace only the camera glass or do we need to replace sensors too?
Thanks
Looks like a combined unit. Separating the glass from the sensor (or vice versa) sounds like a delicate job.
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
Altre 5 persone hanno completato questa guida.
Un commento
Hi, I need the part number of the cover with the sensors. The sensors are not working in my device.
