Introduzione
If you need to replace the motherboard of your Xiaomi Mi 4, follow this guide. To gain access to the motherboard, both the back of the device and the battery have to be removed. One should also maintain a hygienic environment and remain statically grounded for the duration of this fix.
Cosa ti serve
Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
Attrezzo utilizzato in questo passaggio:Metal Spudger$2.99
Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
Using the second spudger, slowly work your way around the perimeter of the device
As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
Proceed to gently remove the tape like connector from the battery until it is completely off.
Use tweezer to disconnect battery’s wire from the motherboard.
With the battery removed locate the left-hand cable connected to the motherboard. With the tweezers, firmly grasp the wires of the connector and gently disconnect the cable from the motherboard.
Find the other cable connecting the motherboard to the device at the top right-hand side of the phone, and carefully use the tweezers to remove that as well.
Altre 28 persone hanno completato questa guida.
9 Commenti
Ruined my motherboard to Xiaomi mi4c, do you know where can I buy?
I have broken one of the cable connections on the motherboard ( top one in Step 6). Do you know where I can buy a new motherboard?
you can buy the motherboard on taobao.com
sir i need MI4I motherboard unable to find elsewhere
Mobile # 09060907775
