Salta al contenuto principale
Xiaomi Mi 4 Battery Replacement
Cosa ti serve
  1. Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: passo 1, immagine 1 di 3 Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: passo 1, immagine 2 di 3 Xiaomi Mi 4 Battery Replacement, Rear Case/Midframe: passo 1, immagine 3 di 3
    • Check to make sure that the device is powered off.
    • Use a pin or paper clip to insert in the hole on the side of the phone next to the micro SIM cardholder to remove the tray.
    • Remove the SIM card tray from the Xiaomi Mi 4 and store it somewhere safe.
  2. Xiaomi Mi 4 Battery Replacement: passo 2, immagine 1 di 3 Xiaomi Mi 4 Battery Replacement: passo 2, immagine 2 di 3 Xiaomi Mi 4 Battery Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Metal Spudger
    $2.99
    Compra
    • Using the flat metal spudger and curved metal spudger, make a wedge between the plastic back cover and the inner frame
    • Using the second spudger, slowly work your way around the perimeter of the device
    • Listen for clicking sounds as you are prying the back cover away from the frame
    • As the back cover is almost completely removed, use the suction-cup tool to remove the plastic cover without damaging the back
  3. Xiaomi Mi 4 Battery Replacement: passo 3, immagine 1 di 3 Xiaomi Mi 4 Battery Replacement: passo 3, immagine 2 di 3 Xiaomi Mi 4 Battery Replacement: passo 3, immagine 3 di 3
    • Use a 000 phillips head screwdriver to remove the 10 1.2mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use a 000 phillips head screwdriver to remove the 3 0.5mm phillips head screws in the plastic frame that hold the motherboard and battery.
    • Use the small plastic opening tool and place it in the slot on the bottom right corner of the inner frame and carefully pry it off.
  4. Xiaomi Mi 4 Battery Replacement, Battery: passo 4, immagine 1 di 3 Xiaomi Mi 4 Battery Replacement, Battery: passo 4, immagine 2 di 3 Xiaomi Mi 4 Battery Replacement, Battery: passo 4, immagine 3 di 3
    Compra
    • Use tweezers to gently disconnect the connections that run across the battery and are connected to the motherboard.
    • Proceed to gently remove the tape like connector from the battery until it is completely off.
    • Use tweezer to disconnect battery’s wire from the motherboard.
  5. Xiaomi Mi 4 Battery Replacement: passo 5, immagine 1 di 2 Xiaomi Mi 4 Battery Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to gently pry the battery out of its casing for removal.
Conclusione
Altre 48 persone hanno completato questa guida.
USF Tampa, Team 15-6, Blackwell Fall 2015 Membro di USF Tampa, Team 15-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G6
2 Membri
10 Guide realizzate
24 Commenti
Sir, I accidentally put a hole in battery while removing. Will this create a problem/explosion..
Apawilo Zawk - Replica
Hey Apawilo. A punctured battery has potential to be very dangerous (Fire, harmful chemicals, etc), so please make sure to dispose of it at the nearest e-waste recycling site.
Geoff Wacker -
sir i am charging my phone but its percentage is not increasing ....this is a battery problem
adishsaggar123 - Replica
im having the similar problem, when charging power increase slower and the consumption is faster than usual. please advice. thanks
Zeff Soo -
Hi..my xiaomi 4 cant be started.. after fully charged, it went blank n cant be restarted.. few days back, it was on n of for multiple time for several minutes...
Ezrat sam - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 19
Ultimi 7 Giorni: 51
Ultimi 30 Giorni: 167
Tutti i Tempi: 147,643
