Introduzione
Use this guide to replace a faulty motherboard in your Xiaomi Mi 3 smartphone.
The motherboard is a piece of hardware that allows for components of a phone – such as RAM, CPU, memory, and other components – to communicate with each other. A faulty motherboard will make your phone unable to boot up or cause it to frequently crash. It can be damaged by an overheating battery, dropping the phone, or using incompatible chargers.
Be aware that an improperly installed battery can lead to overheating and swelling of the battery, which can further damage the motherboard and potentially cause a fire.
Before beginning, make sure to power off your phone completely and disconnect from any external power source.
Cosa ti serve
Firmly press the SIM card removal tool into the hole located at the top of the phone to eject the SIM card tray from the slot.
Place the front panel screen side down with the camera at the top.
Remove these six Phillips head screws located at the upper half of the phone.
This screw is located under an orange sticker at the top right corner of the panel. The sticker can be removed with a pair of tweezers, then remove that Phillips head screw.
Next, remove these three screws located at the bottom of the back panel.
Using tweezers, remove the rubber dust cover on the back panel of the phone.
Why do you need to remove that ?
This step is 100% unnecessary.
Using a spudger, remove the small ribbon cable that is connected to the battery.
Thank you, i changed the battery mi3 easily. I dont need steep 9,10,11. I removed nfc stickers that stick to battery and attached to top cover carefully, make it top cover and antenna nfc still integrated. Mi3 Battery is removed Due problem "Bootloop mi logo without android, and you can enter fastboot only, no matter it sucessfully flashed via fastboot room it will stay bootloop". So, yes, if the battery not good, it will goes to bootloop automatically.
I have the same problem. I think my battery also dead! Good information!
Remove the battery by gripping and pull up on the "Battery Removal" tab attached to the left side of the battery on the back panel.
Use of an old credit card to help lift the battery Is much easier.
Disconnect the antenna wire that is attached to the lower left side of the motherboard using the pry tool.
Using a pry tool, gently lift the side control buttons assembly away from the case. They should be loosely connected to the motherboard.
This step Is absolutly NOT needed for motherboard removal.
You will people brake flex doing so. Limit your guide to necessary step only!
Altre 8 persone hanno completato questa guida.
7 Commenti
Mi have problems with my mother board i am nt getting it anywhere in the servce center sggst me where i can get it.
I know one in the Moscow)
I can send to you bricked mainboard. Unsucsessful flashing, but you can rise up it in 9008 mode. If interesting - write to me.
My sound is little bit cracking, what to do..plz help me.
Redmi note 3...and my back panel little bit holed...i want remove my panel....
i required mi 3 motherboard,…i want motherboard, plz help me…
