Salta al contenuto principale
Xiaomi Air 12 Trackpad Replacement
Cosa ti serve
  1. Xiaomi Air 12 Trackpad Replacement, Rear Casing: passo 1, immagine 1 di 1
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
  2. Xiaomi Air 12 Trackpad Replacement: passo 2, immagine 1 di 3 Xiaomi Air 12 Trackpad Replacement: passo 2, immagine 2 di 3 Xiaomi Air 12 Trackpad Replacement: passo 2, immagine 3 di 3
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 Trackpad Replacement: passo 3, immagine 1 di 2 Xiaomi Air 12 Trackpad Replacement: passo 3, immagine 2 di 2
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 Trackpad Replacement: passo 4, immagine 1 di 3 Xiaomi Air 12 Trackpad Replacement: passo 4, immagine 2 di 3 Xiaomi Air 12 Trackpad Replacement: passo 4, immagine 3 di 3
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 Trackpad Replacement: passo 5, immagine 1 di 2 Xiaomi Air 12 Trackpad Replacement: passo 5, immagine 2 di 2
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 Trackpad Replacement, SSD: passo 6, immagine 1 di 2 Xiaomi Air 12 Trackpad Replacement, SSD: passo 6, immagine 2 di 2
    • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
  7. Xiaomi Air 12 Trackpad Replacement: passo 7, immagine 1 di 2 Xiaomi Air 12 Trackpad Replacement: passo 7, immagine 2 di 2
    • Remove the 1.5mm screw using the JIS #00 screwdriver.
  8. Xiaomi Air 12 Trackpad Replacement: passo 8, immagine 1 di 2 Xiaomi Air 12 Trackpad Replacement: passo 8, immagine 2 di 2
    • Lift the SSD up from the device and gently pull the SSD from the laptop.
  9. Xiaomi Air 12 Trackpad Replacement, Battery: passo 9, immagine 1 di 1
    • Detach the red wire from the tabs on the perimeter of the metal bracket.
  10. Xiaomi Air 12 Trackpad Replacement: passo 10, immagine 1 di 3 Xiaomi Air 12 Trackpad Replacement: passo 10, immagine 2 di 3 Xiaomi Air 12 Trackpad Replacement: passo 10, immagine 3 di 3
    • Use a PH1 screwdriver to remove the five 2mm black screws.
    • Remove two silver 1mm JIS #00 screws.
    • There will be clear plastic spacers that come off with the silver screws.
  11. Xiaomi Air 12 Trackpad Replacement: passo 11, immagine 1 di 3 Xiaomi Air 12 Trackpad Replacement: passo 11, immagine 2 di 3 Xiaomi Air 12 Trackpad Replacement: passo 11, immagine 3 di 3
    • Lift the battery up and pull out from the device.
    • The metal bracket will come out with the battery.
  12. Xiaomi Air 12 Trackpad Replacement, Trackpad: passo 12, immagine 1 di 1
    • Orient the computer so that the trackpad is closest to you.
  13. Xiaomi Air 12 Trackpad Replacement: passo 13, immagine 1 di 2 Xiaomi Air 12 Trackpad Replacement: passo 13, immagine 2 di 2
    • Disconnect the trackpad cable from the motherboard by inserting the plastic opening tool under the white tab of the connector and pry up the white tab.
  14. Xiaomi Air 12 Trackpad Replacement: passo 14, immagine 1 di 1
    • Gently remove the cable by pulling it out from the connector.
  15. Xiaomi Air 12 Trackpad Replacement: passo 15, immagine 1 di 2 Xiaomi Air 12 Trackpad Replacement: passo 15, immagine 2 di 2
    • Use a PH1 screwdriver to remove the three 2 mm screws.
  16. Xiaomi Air 12 Trackpad Replacement: passo 16, immagine 1 di 3 Xiaomi Air 12 Trackpad Replacement: passo 16, immagine 2 di 3 Xiaomi Air 12 Trackpad Replacement: passo 16, immagine 3 di 3
    • Lift the top end of the trackpad at a small angle and pull the trackpad out.
Conclusione
Hannah Kwan
Membro da: 04/18/18
824 Reputazione
5 Guide realizzate
Cal Poly, Team S18-G4, Livingston Spring 2018 Membro di Cal Poly, Team S18-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G4
4 Membri
20 Guide realizzate
Un commento
Hi. where can i find this touchpad? actually for 13.3 one
Alex Palance - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,822
