Salta al contenuto principale
Xiaomi Air 12 Battery Replacement
Cosa ti serve
  1. Xiaomi Air 12 Battery Replacement, Rear Casing: passo 1, immagine 1 di 1
    • Orient the computer so the Xiaomi logo is at the bottom of the device.
  2. Xiaomi Air 12 Battery Replacement: passo 2, immagine 1 di 3 Xiaomi Air 12 Battery Replacement: passo 2, immagine 2 di 3 Xiaomi Air 12 Battery Replacement: passo 2, immagine 3 di 3
    • Insert the plastic opening tool underneath the top-middle rubber covering and lift upwards to reveal the hidden screw.
  3. Xiaomi Air 12 Battery Replacement: passo 3, immagine 1 di 2 Xiaomi Air 12 Battery Replacement: passo 3, immagine 2 di 2
    • Remove the eight 3 mm screws using the Torx T5 driver by inserting the screwdriver into each screw and rotating counterclockwise.
  4. Xiaomi Air 12 Battery Replacement: passo 4, immagine 1 di 3 Xiaomi Air 12 Battery Replacement: passo 4, immagine 2 di 3 Xiaomi Air 12 Battery Replacement: passo 4, immagine 3 di 3
    • Insert the plastic opening tool into each side of the computer and push the tool downwards to pop open the back cover.
    • You will hear popping noises as you remove the cover.
  5. Xiaomi Air 12 Battery Replacement: passo 5, immagine 1 di 2 Xiaomi Air 12 Battery Replacement: passo 5, immagine 2 di 2
    • Remove the back of the laptop by gently lifting the casing upwards.
  6. Xiaomi Air 12 Battery Replacement, SSD: passo 6, immagine 1 di 2 Xiaomi Air 12 Battery Replacement, SSD: passo 6, immagine 2 di 2
    • Detach the white and black speaker wires by pulling them from the small black tabs along the perimeter of the metal bracket.
  7. Xiaomi Air 12 Battery Replacement: passo 7, immagine 1 di 2 Xiaomi Air 12 Battery Replacement: passo 7, immagine 2 di 2
    • Remove the 1.5mm screw using the JIS #00 screwdriver.
  8. Xiaomi Air 12 Battery Replacement: passo 8, immagine 1 di 2 Xiaomi Air 12 Battery Replacement: passo 8, immagine 2 di 2
    • Lift the SSD up from the device and gently pull the SSD from the laptop.
  9. Xiaomi Air 12 Battery Replacement, Battery: passo 9, immagine 1 di 1
    • Detach the red wire from the tabs on the perimeter of the metal bracket.
  10. Xiaomi Air 12 Battery Replacement: passo 10, immagine 1 di 3 Xiaomi Air 12 Battery Replacement: passo 10, immagine 2 di 3 Xiaomi Air 12 Battery Replacement: passo 10, immagine 3 di 3
    • Use a PH1 screwdriver to remove the five 2mm black screws.
    • Remove two silver 1mm JIS #00 screws.
    • There will be clear plastic spacers that come off with the silver screws.
  11. Xiaomi Air 12 Battery Replacement: passo 11, immagine 1 di 3 Xiaomi Air 12 Battery Replacement: passo 11, immagine 2 di 3 Xiaomi Air 12 Battery Replacement: passo 11, immagine 3 di 3
    • Lift the battery up and pull out from the device.
    • The metal bracket will come out with the battery.
Conclusione
Altre 9 persone hanno completato questa guida.
Hannah Kwan
Membro da: 04/18/18
824 Reputazione
5 Guide realizzate
Cal Poly, Team S18-G4, Livingston Spring 2018 Membro di Cal Poly, Team S18-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G4
4 Membri
20 Guide realizzate
5 Commenti
I have a problem, the battery do not really charge, 100% is reach in few minutes, and it works less than 15 minutes on battery. Is anybody have a solution ? Bios update maybe ?
Migwell2 - Replica
I got to pull out my bloated battery…. Though it could work with just the charger on stand by but it did not… Anyone knows where I can purchase new battery? Can't bring it to the shop because of quarantine but need to work from home.
Roma Monica Desunia - Replica
I removed the bloated battery too. It can’t power on properly. The power light just just on and off around every 5 seconds. Is yours the same?
sdot -
after I change the battery it always says plugged in not charge, anyone has the same issue?
Anthony Jethro Lieander - Replica
Hi. There is no page for keyboard replacement so I'm asking my question here: how can I find a keyboard replacement for my mi 12.5 notebook? Only two buttons do not work.
Hamed Mirrezaee - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 87
Tutti i Tempi: 7,785
