Salta al contenuto principale
Xi-Electronics 7 inch Tablet DC Jack Replacement
Cosa ti serve
  1. Xi-Electronics 7 inch Tablet DC Jack Replacement, dc jack recharger connector: passo 1, immagine 1 di 2 Xi-Electronics 7 inch Tablet DC Jack Replacement, dc jack recharger connector: passo 1, immagine 2 di 2
    • to open the device , You use a isesamo opener .
    • Just pry the device open but be gently and cautious
    • at the second picture you see how the inside looks like.
  2. Xi-Electronics 7 inch Tablet DC Jack Replacement: passo 2, immagine 1 di 2 Xi-Electronics 7 inch Tablet DC Jack Replacement: passo 2, immagine 2 di 2
    • now gently remove the first connector circkled in red
    • use a toothpick dental tool to open it. or use a small flathead screwdriver or something similar.
  3. Xi-Electronics 7 inch Tablet DC Jack Replacement: passo 3, immagine 1 di 3 Xi-Electronics 7 inch Tablet DC Jack Replacement: passo 3, immagine 2 di 3 Xi-Electronics 7 inch Tablet DC Jack Replacement: passo 3, immagine 3 di 3
    • remove the second connector.
    • first remove the orange tape by peeling it of.
    • then remove the black thick tape on the connecotr
  4. Xi-Electronics 7 inch Tablet DC Jack Replacement: passo 4, immagine 1 di 1
    • remove the third connecor , it is next to the connecotr in step 3.
  5. Xi-Electronics 7 inch Tablet DC Jack Replacement: passo 5, immagine 1 di 1
    • remove the screws of the main board.
  6. Xi-Electronics 7 inch Tablet DC Jack Replacement: passo 6, immagine 1 di 2 Xi-Electronics 7 inch Tablet DC Jack Replacement: passo 6, immagine 2 di 2
    • after removing the mainboard , you'll see the missing dc jack.
    • we will solder the dc jack on the main board.
    • before you do this, search the internet on how you have to solder !! and use the right tools, dont buy the cheapest tools.
  7. Xi-Electronics 7 inch Tablet DC Jack Replacement: passo 7, immagine 1 di 1
    • i didn't put pictures or movie on how to solder in this guide, but you will find lots of info on the internet. in the last picture you'll see the new dc jack.
Conclusione
Altre 6 persone hanno completato questa guida.
Kevin D
Membro da: 05/02/14
7.316 Reputazione
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,244
